1995SHO9
FLEES ARE COMIN
I was having a problem with my 95 MTX SHO and since all of you guys have been helpful before, I thought I would post asking for some advice again.
My SHO started idleing hi for some reason. When I start it up in the mournings, it is fine. However when I start driving and come to a stop, the idle stays at 2000-1400 RPM's Sometimes it will return to about 800 RPM's although it drops slowly. What puzzles me is that it doesn't do this all the time, somtimes it will return to like 800 RPM's while I am stopped quickly. I don't know if this helps but the car isn't idling rough or anything. The other day however when I started the car up it was idling up and down quickly at around 1200-1000 RPM's quickly. (I believe right around there, I wasn't paying as much attention to it as I should have) This almost reminded me of the way a car idles with a cam. This however cleared up when I gave it alittle bit of gas.
I don't know if this will help at all to diagnose the problem, but I also had the trannsmission out recently. It never idled highore that, however it did idle up and down quickly at start up once. This was like I mentioned above, siimialr to the idle of a car with a cam but a little faster.
Well I hope you guys can help me out, thanks in advance for you help..
John N
John N
