Hesitation?
91 Plus
Well-Known Member
Monroe,Michigan
Ok this is kinda hard to explain but here goes nothing..My car seems to wanna hesitate real bad and sortta **** the car...It is when I am giving like half throttle through all the gears..It is really weird.Kinda seems like its not getting enough fuel or something?Anyone help with the little info?
BenBrausen
Minneapolis, MN USA
I had a problem with my SHO hesitating and then it wouldn't go over 80mph this winter. All that was wrong was a dirty MAF meter. I don't know?
Is it misfiring? That could be plugs or wires. If not, test the throttle position sensor. AutoZone will test it for free. The Wells TPS215 is $19 at AutoZone.
91 Plus
Well-Known Member
Monroe,Michigan
bckicked:
can you bring the car over on thurs or fri after 7:00 pm and i will check it out for you.
Brett
Well I actually am working 11 days straight right now cause I need money...I will see if i can get off kinda early one of those night and I will call you if so..Thanks brett
Chris Benvie
Every so often
RedSox Nation
Hey i've read post your posts, did you wash your motor with a hose? I've seen this happen when shit gets wet
