Help !!!!
SHO 508
Brockton
I tried everything to make my car run which i already put new battery and alenator so it keeps dying ..... the computer is showing 112 ACT sensor circuit grounded , i dont even know where it is at ...any pictures will be helpful ...thanks
hawkeye18
Sorta cares
Norfolk, VA
Isn't the ACT (Air Charge Temperature) the little sensor in the airbox under the filter? Also, look at the IAC, which is the shiny cylindrical thing next to the throttle body on the other side of the intake. That controls air at idle (Idle Air Controller). Make sure it's plugged in and replace it if necessary. That's usually why a car won't idle if it starts. At least as far as I know. And hey, look at the announcement right above your post where it says "don't use titles like 'help!!!'". Take to heart :). It's ok, we still love you.
SHO 508
Brockton
I'm stll having the problem ... the problem is something that has drained the battery every time i drive for around 30 minutes then it wont start...it even has new starter , alt and battery ..what else it suppose to be ...the batter light go on real lil bit till i give more rpm 2,000 rpm ... when it goesback tro 1,000 the battery light goes on.
all i know it says 112 code... i dont even know where it is.
Redskull
Badass Mo'fo
New Haven, CT
sounds like a crappy rebuilt alternator to me; check the voltage at the battery posts at idle, make sure it's like 14v. Also, a quick check, make sure the battery light comes on when the car is in turned on (in 'run') but not started.
