Here's some threads for checking the fuel pump. The last post has the pin outs for the CCRM
Well, its an issue with the fuell pump or related circitry. THe code is a 542; fuel pump secondary circut failure, EAC to ground? What exactly does this mean? The car started at first, then I stalled it and it wouldn't restart. I noticed that when the key is turned on the fuel pump was not...
shoforum.com
I had a no fuel pump working issue. I purchased a new one from shosource. It powered the FP one day but not the next. I tested in and outputs per info found on site. I found all testing to be correct accept can't get pwr output on pin 5. Could something short out the new ccrm and how to find...
shoforum.com
So the ccrm that came on the car when I bought it broke, it had a letter M on it and I have now found out that is the right one for my 93 mtx. I bought a module with a J on it from a junk yard and it works but my car isnt recognizing the new cps it seems like. I just wanted to know what will...
shoforum.com
Maybe you can check if fuel is making it to the fuel pressure regulator by loosening a bit and see if fuel comes out at the bottom. It can be removed with the intake still on, its tricky, but can be done
