help wont start
shocrazy
Douglassville PA.
HI i have a 92 mtx and today i whent to my car and nuthing happened i hear the fuel pump start and that is it. it doesnt turn over at all i tried jumping it nuthing happened i had to bump start it to get home there is no voltage drop from the battery when i try to start it either anybody have any ideas what it could be im lost
Ishodu
Do you hear a click or anything? If not it could be that the starter solenoid or the clutch pedal switch for the starter. Could also be the connections on the battery cables. You could start by removing all the wires and cleaning all the connections. You can use a meter to check for voltage at the spade treminal at the solenoid when you turn the key to start. If power is there you prolly have a bad solenoid or wires or starter.
shocrazy
Douglassville PA.
i hear a little click but it doesnt turn over i tried bypassing the clutch pedal switch with a wire and it didnt work and the battery connections look good
Ishodu
Well If you hearing the click at the starter its getting power to fire the solenoid. That means the clutch pedal is OK. Polly your starter or the wiring is corroded or dirty.
