Help.. Need torque specs for........
sho32g
Tampa
If anyone has the SHO helms manual could you please email or post the following.
I need the Torque specs for the following:
Front Camshaft Sprocket bolts (6 bolts in all)
Timing belt Idler pulleys (2 in all)
Water Pump to block bolts
Any help would greatly be appreciated.
Thanks!
Joe
SHOfear
Boston, MA
<strong>
15-18 lbs/ft (21-25 nm) for the cs sprockets, do you mean the nut for the idler pulley?, and 12-17 lbs/ft (16-23 nm) for the water pumo retaining bolts.
Steve
sho32g
Tampa
SHOfear;
Thank You, Thank You, and yes I need the specs for the accessory idler pully (timming belt) upper right side and belt tensioner pulley left lower side.
Thanks,
Joe
SHOfear
Boston, MA
Oh, Ok. You must have a 3.2L then. For the upper pulley, its 26-38 lbs/ft (35-51 nm), and for the lower pulley its 27-41 lbs/ft (36-55 nm).
Steve
