help! need belt for udp. what size?
93fordsho
colorado
So I just put my udp on here at work and I don't know what size belts I need. I need help ASAP! Thanks guys
SuperHO
Mental Patient
St. Joe, MI
i was able to use the stock sized belt for the water pump/power steering, though it took a little fanagaling to get it on. i can't help you with the altenator pulley as i don't have A/C.
Cocoa,Florida
Place your tensioners in the middle of there adjustment range.
Grab a some string or fishing line and go around the pullys just like each belt would and mark them.
AREA 91
PA SHO SHOP
Area 91
I have the SHO SHOP 3 piece pulleys on my cars.
The belt number's for these are:
K060455 (6 rib)
K040510 (4 rib)
tompumped
VT
In case anyone cares I put the recommended belts on a shosource udp, and with the tensioners maxed out I still couldn't get proper tension, but there's enough I guess. I doubt anyone uses a belt tension gauge to check, but I do. I got the part numbers from shosource.
Next time i'm going to get shorter belts and post back.
Phoenix
SHOHOLIC
QC , Canada
Just measure it up and call the part number , The K numbers - last 3 digits are the length of it , a 455 belt is a 45,5 inch , and the 06 is the number of ribs.
Since i got a custom belt setup , I used a old belt , cut it at one end and use it as a template to know how long you need...
93fordsho
colorado
Cool thanks guys. I ended up just calling everyone in the Colorado springs area till I found the ones that fit. I'll post the lengths later so if anyone else is ever wondering its there
