riden2low
Any suggestions on how to remove the front screws that hold the the moonroof in place. Did a search and found all the infro on taking it out and etc but just having a **** of a time getting the two remaining screws out. One screw is so bad that I will have to use a screw extractor or something. I can barely get a pair of needle nose vice grips in there but still can't loosen the screw. And used a lot of penetrating oil too. Is there a way to remove the whole thing and work on it at a bench? All I wanted to do is replace the seal that I got from the sunroof doctor.
