Brett
SHOs before HOs
So my buddy bought a 92-93 green MTX and loves it to death.
He said it started right up, and now it wont start. Cranks over but wont start. I had him pull the codes, and heres what we got:
172 (R,M) Oxygen sensor not switching - system is or was lean - Single, Right orr Rear HO2S - Fuel control
176 (M) Oxygen sensor not switching - system is or was lean Left or Front HO22SSS - Fuel control
212 (M) Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems
216 (M) Primary circuit failure - ignition coil 2 - Ignition Systems
542 (O,M) Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits
To be honest i have no idea what these mean. At first sounds like maybe a spark problem? (erractic tach signal, circuit failure ignition coil 2)
But whats with the fuel pump code? I'm sure he'd appreciate any help he can get, he knows automotive basics but thats about it.
