HELP!Cooling fan assemblies 93, versus 95 MTX
platoribs
Live to Drive
Plat0ribs House of SHO,il
I broke the shroud assembly on my 95 mtx and have been having a lot of problems trying to replace it. I got a used 93 assembly and wanted to swap the 95 fan motor in but the fan blade wouldn't fir without clearance issues, then I trimmed the gussets inside the fan blade to get it to fit ad found the motor had some other issues. Does anybody know which fan assemblies fit which and where I can find one to fix my broke 95 unit. Will the 3.8 SLO assembly work?
HELP!
Redline
Fire It Up
Sandpoint
I'll know in a couple days if the SLO one will work or not. I picked one up for $10 on ebay for my 95 mtx so I figured if it doesn't work not much loss. The assemblies are harder to come by for a 95, at least for a reasonable price unless you find one at a junkyard. I don't know which all work for which but if you do a search you should find something.
