SinisterSHO
Rust free
Alright, last night I go to come home from work. Car no start. All I have done since having the CPS replaced was install my 80 MM Maf and install the Tweecer. So, its not starting at work. I pull the tweecer, I plug in the LPM, I pull the LPM, I unplug the ground, I plug everything back in. Then it starts. This morning, same thing.
Tonight, I go to leave work, nothing. I go through the same deal, nothing. I check the inertia switch, nothing. I have not had a chance to check my codes, and I'm hoping I can get a hold of a scanner tomorrow, or I will attempt the paperclip thing. But I suck at that.
Someone mentioned the IRCM. I dont think it is the fuel pump because I haven't noticed any other problems. And it isn't even making a noise. This seems sudden, and I hope it is something simple like an IRCM.
Anyone have any other suggestions on things to check? I will post tomorrow with codes info.
