Helicoil cam caps. Questions. Guide cap PLEASE!
zach44102
BIG TURBO
Georgia
I bought a M7-1 helicoil kit and I read while searching I needed to remove the guide caps. The little rings that go over the hole where the cam cap bolts go through.
I tried to remove it with needle nose vise grips but there is just not enough material there to grab it and yank it up. Can I do this without removing them? My drill bit fits through it but the tapping tool does not.
I practiced removing the "guide caps" on a old motor I had laying around and I could not remove them without damaging them. So my 3 questions are.
1. How do you remove them without damaging them?
2. If I do damage them is there a way to get new caps?
3. Can I not use caps?
yamahaSHO
E85 whore
Arkansas
Those are locating dowels... I would NOT remove them (MOST CERTAINLY DO NOT LEAVE THEM OUT OR DAMAGE THEM). You should be able to drill and tap with them in place.
Personally, I would take it to a machine shop and also have studs fitted.
zach44102
BIG TURBO
Georgia
The tap does not fit through the dowel. Now I know do not remove them. Now where can I get new ones or how can I remove these safely. I used a pair of vise grips on to get the ones out of a old motor but it bent them up in the process. Is there a tool I can use to get them out?
zach44102
BIG TURBO
Georgia
these are the dowels.
084fc1a0
After removing them this is what they looked like. Maybe I could bend them back into shape?
E73bca67
kevinspann
Don't take my advice.
Richmond VA
You aren't going to be bending that back into the right shape. Don't get frustrated and try on your good motor.
AREA 91
PA SHO SHOP
Area 91
I wish I could remember how I did mine years ago, but I don't.
I do remember removing those so the tap would fit.
bmytych
