Heating up!!!
randy'sho
95 White MTX
High Point, NC
hey there i am new @ shoforum and i have a few questions for you guys! I'm a huge sho nut i have a red 93 mtx and a silver 89 (obviously an mtx also). i store my 93 for the winter but last fall i was having problems with it heating up and i found out that my fan is not coming on.....i checked all the relays and fuses...still nothing! i ran down the wiring but i can't find anything....my next step is to replace the fan motor, but i don't want this to be a nickel and dime thing and then find out that it was an easy fix...if anyone has any suggestion i would love to hear them.......one other thing...where exactly is the iac on the throttle body? i think that mine needs cleaning, when i first start it, it jumps between 800-1500 rpms....i would really appreciate your guys help...thx
JATRAMMELL
93 Red ATX
CLEMMONS NC
Search forum under "cooling fan" for pertinent info. I am using a flex-a-lite switch to get mine to come on. It's probably not the fan, but you need to check it. Does the fan come on when you turn the A/C on?
laxmax327
philly
the iac is a few inches to the left of the throttle body. the little tubular thingy.
SHO>*
Blaine, MN
Sounds like a bad ECT to me. If you're standing at the drivers side it's below and to the right of the tstat. 1" round brass lookin thing with a 2(?) wire plug going into it.
randy'sho
95 White MTX
High Point, NC
no my fan doesn't come on at all...even when i put it on max air and sorry i forgot to tell you, the first thing that i did was change the ect but still a no go!
stangeater
Farm Boy
Get a new car you freak, your's is junk! :snicker: ..............Randy is my brother, so I'm just giving him some crap! :thumb:
JATRAMMELL
93 Red ATX
CLEMMONS NC
When I was checking my fans out prior to getting the flex-a-lite switch, I probed pin 14 going to the CCRM with a test light--with the key on, of course. When I did , the fans came on. Grounding pin 14 with the key on will tell you if your fans work or not.
randy'sho
95 White MTX
High Point, NC
okay what exactly is the ccrm....sorry if that sounds dumb, i am tired of running wires down....what is the ccrm and where does it run. i have probably had my hands all over it and didn't know it! thx
SHO>*
Blaine, MN
ccrm=constant control relay module (sometimes also referred to as the IRCM). It's in the driver's side front of the engine bay under the plastic guard. It's a black box approximately 4"x4" laying horizontally with an electrical plug going into it.
randy'sho
95 White MTX
High Point, NC
i tried grounding that pin 14 but i got nothing....so i took out my entire fan and housing and put it on my 89 and it comes on perfectly....i was noticing that in my 93 my ccrm says J and in my 89 it says M...know correct me if i'm wrong, but does'nt all mtx's have a M ccrm? anyways, i put my 89's ccrm on my 93 and still nothing....anymore help? maybe i'm not ground that pin correctly, how exactly did you do it? i tried a test light but got nothing, so i thought maybe you had some special technique....
