Heater Problem...
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
ok so i think ive finnally narrowed it down, and here is the story...
it started where i didnt have heat... code 02 (blend door actuator)
then i replaced the BDA, and the one in there was truly bad (teeth stripped off)
still code 02, heat full-on, BDA not moving.... checked fuse #17 = blown (only by testing resistances could i tell that it was blown) (fuse 17 runs the BDA Control unit, and blower motor speed controller)
WENT BACK TO SCHOOL AFTER CHRISTMAS BREAK (heat worked, but i couldnt change the temperature)
this weekend i am home again... its 15 degrees outside and NOW my heater fan does not work... when i got home from the short drive i took i then disconnected my speed controller @ the glovebox, and the fuses stopped blowing, i reconnected it and they blew again.... so i think its the speed controller that is the culprit (also fuse 9 (30A blower motor fuse) is good, so it isnt the motor causing me to not have a fan)
so if i replace the speed controller could this solve both the problem of no fan and the other problem of no heat adjustment? is it possible that after a few <0 degree days could have been the last blow for the speed controller (since it was already on its way out because it was blowing fuses)
Devin
3.Slow
Pacific Northwest
I'm trying to solve a blower motor problem myself, and according to alldata, the IRCM controls functions of the blower. Not quite sure how to troubleshoot that besides swapping in a different one.
