Heater Core took a crap. Bypass question
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
So my heater core decided to take a dump on me last week. Just in time for the cold weather.
I currently have it bypassed, but I need it to be "Hooked up" for an upcoming inspection.
Is there an issue if I plug the inlet and outlet of the core and hook up the hoses as normal?
I would be dead heading the inlet hose to from the engine to the core.
Will it blow the hose?
sperold
Last to Know
The water pump is a centrifugal pump, so you can dead head it on that circuit.
A positive displacement pump (gear pump) does not like to be dead headed.
its not like that is the only place the water can flow, so it should not be a problem to block off the heater core as you suggest.
