headlight questions
rcsavage
Florida
just making sure what im thinking of buying is all going to go together correctly and not fry instantly.
ok so will these bulbs be ok:http://cgi.ebay.com/ebaymotors/NEW-...ewItemQQcategoryZ33710QQitemZ8012533867QQrdZ1
will the headlight wire haness from here be ok:http://suvlights.com/
what else would i need, if anything?
what confuses me about the harness is that there are two pictures that look alike but the second one i dont understand. basically, which harness do i get for those bulbs.
http://suvlights.com/wireharness.jpg
or
http://suvlights.com/90059006wireharness.jpg
SolidState
No Mo SHO
Toronto, Ontario, Canada
the first one.
The first one is for the 9007, which I am assuming you have a 92-95 Gen2. The second one is for a 9005 or 9006, which isn't applicable to any taurii. I believe the Gen1s use a 9004...which will use the same harness, but wired a little differently...
khanartist
oldtimer....
Windsor, ON, CA
9005 & 9006 setups are for the dual GM type hi-low beam setup. Not even close to our SHOs. SHOs run the dual filament hi-low, one bulb. 9007 is what you need.
IMO SilverStars aren't that wonderful, but this is a topic of much debate.
rcsavage
Florida
ok sorry. i have read around about lights and assumed the gen I and gen II bulbs were the same. my mistake. I have a gen I. so i need a 9004 bulb? if it is 9004, what harness is it. when I order the harness will it ask me what type i need? sorry, its my first time upgrading the headlights.
SolidState
No Mo SHO
according to that site, the 9004 is a similar connector, but is wired up a little bit differently...
are you looking at teh standard harness, or the HD 9004/9007 harness?
