Head light case
N3FOL
Pennsylvania
Can anyone tell me where I can find factory head light case? As much as possible, I do not want to get it from a dealer. Reason: My head lamp plastic from the exterior looks weathered out. It has changed color due to the weather...
Can it be cleaned? Or just replace it with a new one...??
68style
Richmond, BC, Canada
N3FOL:
Thanks for the reply. I have a 1995 SHO. Can you help me on this?
Easy, every single Mercury Sable ever made from like '92 up to '95 used the exact same headlight unit, so just pick one up somewhere off a junked one or whatnot.
N3FOL
Pennsylvania
That might be a great idea to go find a junk yard and hope that they have one. My biggest challenge here is where can I find one. (perhaps the yellow pages???) Anyway, thanks for the reply.
Derek
Saugus,MA
I forget what the difference is between the sable headlenses and the SHO lenses they fit the same but theres a slight difference I cant remember what it is but when I do I'll let know... I read it somewhere because I am on the same mission!!!! thumbs_u burn_out
jcostantino
Coral Springs, FL
The 92-95 Sable lens's should be identical to the SHO. You can buy new (generic non-Ford) from: http://store.yahoo.com/dpstore/dp-h01510.html (those are new for $85 each).
Or you could of course get used ones which are usually about $40 each at salvage yards.
I put some NuLite on my car, it's an acrylic glaze that comes in a special kit. Others have applied fiberglass gelcoat or clear paint to their lenses after sanding and polishing.
Jeff
N3FOL
Pennsylvania
Derek...Thanks for your reply. I'll be looking forward to your next message regarding headlenses of the Sable fitting into an SHO. thumbs_u
