Has anyone Installed DD size receiver?
rigol2000
Need a 60k
Southern Louisiana
Has anyone installed a DD (Double DIN) sized receiver in the space where the CD and Tape deck are? I know the front face shouldn't be too hard to modify, but I'm not sure about inside the dash. If you have, do you have any pictures?
Thanks :wave:
Chris
SASHO91
Zoom Zoom
San Antonio,TX
IIRC, ohioshodude has one in his genI....
maybe he will chime in...
you could try and find it under "all threads started by" in his profile....
ohioshodude
SHO'ld fogy
delaware, ohio
well din and a half, hehe i installed a mach audio unit in my 91 mocha. not too many problems. theres plenty of room behind it.
you'll have to modify where the radio and cd player go now, cutting out the center "clip" between them. with a full double din unit there shouldn't be much of a space above or below the unit. on mine being the ford 1 1/2 din size i had to use a blank plate to hide the hole.
if your consern is space, there is plenty.
rigol2000
Need a 60k
Southern Louisiana
Thanks, I figured there should be enough space in there but wanted to verify. The railing that holds the CD player up was my concern. As far as the face of the unit, I wanted it to fit completely in the two openings in there now.
I'm making my wish list and didn't want to put this on there unless it was realistic. :thumb:
Thanks,
Chris
carterh
Calgary Alberta
I had to get a Pioneer CD/DVD with in dash 7"... I mean how else could I possibly have filled the extra hole?!
rudedog
madness sucks
Houston, Tx
Hey,thanks Mario, I'm surprised I didn't see this thread. I had my stereo stolen back in 02 and I found a Focus Blaupunkt. Wasn't sure it would work and after some very lengthy searching(a couple of months), finally found the connectors I needed. It's been a great STOCK substitute for the last few years with no problems what so ever. The ONLY thing I don't like about it, is that neither Ford nor Blaupunkt saw fit to make the SUB out functional, using a line out IS the only way. Any way so far my reasoning behind using a stock LOOKING head unit to deter theft has worked great. Here's some pics.
Dscf1032
in cd mode...
Dscf1033
tuner mode...
Dscf1034
ohioshodude
SHO'ld fogy
delaware, ohio
i supose i should post mine as well to give you an idea. though with a true double din there would only be very small gap above or below the unit. with the one above and mine they are the din and a half that are in most newer fords.
anywhoo on to the pics.
Newradio3
Newinterior
old pic. can't seem to find a newer one. i now have gen III seats so those ratty ones be gone. :thumb:
whiteman_01
Well-Known Member
Hastings, MN
I am looking at doing the same thing with the pioneer dvd nav unit. Please post pics when you have yours installed.
rigol2000
Need a 60k
Southern Louisiana
Those are some great pics. Thanks for posting them. Once I have the money to put into a 7" DVD unit with navigation, I'm going to give it a try. Seeing what a larger unit looks like, I know I'm not wasting my time.
rigol2000
Need a 60k
Southern Louisiana
OK, this is not a real photo... BUT this is what it would look like with a DD DVD unit with Nav installed in the two stereo openings. I photoshoped a Pioneer unit into my 94 Mocca. I have to admit, it looks pretty nice! :naughty: If you have the money, go for it!
SHOwith nav photoshop web
:cool:
Mechanicsville MD
Newradio3
Newinterior
hold on...the gen 2 center console is a direct bolt on??....i want one!
