First off, I want to say you guys have a God Send for me over the last 2 weeks, helping me solve my problems with my SHO. A month ago, the car stalling,but would generally restart after a few minutes. Codes were 212 and 214, I mistakely believed that it was the DIS, after $180 wasted on it. I realized that that it was the CPS due to leaking water pump, only because I found your web site. So last weekend, I tore in the front end and replaced the CPS, CID, Water Pump and Timing Belt. I verified that all three white lines on the timing belt matched the dots on the pulleys, gapped the CPS at .03 and everything went back togather and it started on the first try. Test drove and everything was fine. The next day I drove to work, everything fine till I was heading home. The car started to miss and then it died. It was hard to start but was able to get it to run and the only code that that time was 512 or 514 sometime about memory test failure. I got it off the freeway and check all the connector. At this point still hard to start, like the timing is way advanced and new codes came up the old 212 and 214. Also the Tach stopped working but the engine was running... I was able to drive it home but had to be careful to keep it from pinging. I try starting it today, same thing..hard to start, like it's advanced, but will start and run fine, but CEL comes on and stays on and no tach. Please help, can't believe that I need to replace the CPS.
Thanks in Advance
Al
Thanks in Advance
Al
