seraphiem
No grinding, no noises, I just cannot get the gear selector FULLY seated into gear. Sometimes 2nd, 3rd, and even 5th. Yet always happens to 4th. Grrrr. This just started today!
I have an OEM clutch/PP/TOB that the first owner put in at 133k and I'm now at 197k with a Jose SHOrt shifter. I think I'm still on the original cable and quadrant. The clutch pedal will not click when I pull up on it.
I've also have a rattle from 2k - 3k revs on acceleration which I assumed was the TOB hitting the PP fingers. So I knew a clutch job was coming.
I have a Quaife sitting here waiting for me to install once I order a new clutch kit. My MTX has shifted fine since I bought it 14k miles ago so I did not attempt to find any used synchros or blocking rings when I pull it apart.
The MTX shifts fine when the car is off. Should I begin the search for synchros? Or am I correct in my assumption that this is a clutch issue?
Thanks All.
Thanks All.
