Ground Wires To Intake???????????????
fastsho92
SHO POWER!!!
Exton P.A.
I just put on a new fuel rail on my car as well as some other components such as belts and new knock sensor. when i had the intake off i took it all apart and bead blasted it and polished it. then i put the car all back together and it will not start. i double checked the intake and i found out that i forgot the ground wire on the passager side of the intake. after i hooked that ground up it really wanted to start but it just wounldn't do it. i was woundering if there is another ground somewhere that i am missing or if there is something that i might have missed that would stop it from starting. Thanks :bonk:
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
that it the only ground wire that is attached to the intake.
something to check:
cross-over tube to intake bolts. make sure they are tight.
Those bolts play a huge part in making sure the DIS functions properly ;)
fastsho92
SHO POWER!!!
Exton P.A.
whats this cross-over tube ur talking about. is it the tube from the fuel regulator?? and if the DIS box got water or something on it, and it got messed up some how will that stop the car from running or starting
