Got a question for all the stereo experts...
93redATX
SHOForum O.G.
WI
OK, this one is stumping me and my g/f's brother, who installs car stereos as a side job. Anyway, I have all stock in my car, with the exception of the head unit (Pioneer DEH-P1100), and the subwoofer (10" Jensen tube from Wal-Mart). The tube actually sounds nice, but for some reason it sounds the best if there is a lot, I mean A LOT of airspace around the sub. With the trunk closed and all windows up and everything, there is virtually no bass. But when I open the trunk, or even a car door, the sound gets much fuller and deeper. I've tried a few different positions for the tube with little or no change in effect. And also, it's a ghetto-rigged sub since it's 4 channel and only using the factory sub amp. Is this sub just poorly designed, or is there something I'm missing? TIA
-Andy
'93 Red/Black ATX
"Nemesis"
"The Daily Driver"
-Coneless
-Red interior lights
-Fog light mod
-Pioneer DEH-1100 45x4 MOSFET Head Unit
-SHO lettering painted black
-SHO banner on windshield, SHOforum.com sticker on back window, bottom center
-Gen IV Taurus emblem on trunk
Just Added:
'89 Light Titanium/Grey MTX
"Aphrodite"
"The Project Car"
-K&N Panel Filter
-Poor Man's Ram Air
-Boxless
My Website: http://taurusshosite.8m.com/main.html
AIM:Juggalo53048
RickieFrat
La Cosa Nostra
State of Corruption - RI
Seems the sub is poorly designed. Try keeping the port of it facing the rear bumper. This way you will get the bass bouncing into the car. If the ports are facing any other way it will just bounce all around the trunk.
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Actually What it might be is that the sub is just to weak to cause the trunk to put out the bass. Most bass tubes are not very good and when you have it hooked up to a low power amp thats not desgined for this you will not get a lot of power.
Something else is that I had a friend that decided to run in series the back speakers and a pair of subwoofers from the head unit off of the rear power source. IT cause him a lot of problems, his CDs came out very hot and sometimes the head unit would cut out.
92 White SHO
HiRevs Stage Competion Clutch
SHOSHOP Engine Mounts
Koni Shocks
StrutTower Braces
UD Pullies
Awesome Sound System
JonVH
Norwood, MA
93redATX,
Since you got the 10" sub woofer did you remove the factory sub woofer in the middle of the rear deck & just hook the wires up to the 10"?
Let us know how you make out I'm interested in trying the same.
93redATX
SHOForum O.G.
WI
Jon-
Yes, I took out the factory sub & enclosure in the middle. I wouldn't recommend going the route I did though, cause running a 4-channel sub off a 2 channel amp is not a good idea. I figured that since it's a cheap tube and only the factory amp, I don't mind if I burn it out. Drop me a line if you want me to describe more in depth about the procedure. ([email protected])
[This message has been edited by 93redATX (edited 12-17-2001).]
S
SHOFF
Guest
Bass tubes are a very poor attempt to make a vented enclosure the air space inside of tube is less than half of what is recommended they do this to consirve space. What you are doing by opening the window or trunk is leting the sub have more room to breath making up for this tiny enclosure witch it is in . In a properly bult enclosure you will notice little to no gain by opening the window or door
Sho shop cams
80mm mass air
big bore butterflys
underdrive pullys
strut bars, front and rear
cold air intake
high flow y pipe and cads
18 inch quatem tek wheels
eibach springs
2 tvs
dvd
playstation
5000 watt system
www.shoracing.com/pix/g2/donnyc_93sho.jpg
