Good A/C, bad A/C...
MilTownSHO
Horicon, WI
My A/C will work most of the time if its the first time in the day, I've turned it on. It will blow cold for 10-20 minutes and then gradually get warmer and warmer until I have to turn it off. It seemed to last longer today since I kept it on Max A/C instead of Auto. I ran the self check test on the EATC and it came up with no codes. A technican at work said it's more than likely a switch of some kind. Does this sound right? Any ideas or input? It's about 96 degrees here right now and I miss the A/C tremendously when it goes out!
This is on the 92 by the way...
<small>[ June 25, 2003, 03:18 PM: Message edited by: MilTownSHO ]</small>
heath94
Raleigh, NC
Could be a little low on refrigerant causing the coils to freeze up after a few min. of heavy use.
<small>[ June 25, 2003, 04:11 PM: Message edited by: heath94 ]</small>
MilTownSHO
Horicon, WI
Slo-Sho:
Have you checked the clutch gap?
No, is it easy to do? Instructions of SHOTIMES? I just thought of one other thing, today my buttons on the EATC were wet like with condensation if that means anything at all. shrug
Slo-Sho
It wasn't me!
Crossroads, CNY
Using feeler gauges check the clearance between the pulley and the clutch. It should be about .03". You can see what you need to do here.
MilTownSHO
Horicon, WI
Thanks alot, next time it goes out I'll hit it with something like it says on SHOTIMEs and see if it kicks back in to make sure its the gap!
