St Louis SHO
Rollin' coal
Everything is for sale.
2 V8 engines - one has a bad crank and 2 rods, the other has 1 bad piston, make 1 outta 2!! $300 for the pair.
Complete MTX swap - 3.0l, MTX, subframe, steering rack, all AC lines, harnesses, including dash harness, rod shifter, y-pipe, exhaust pipe, etc $500
Performance plus Catted Y pipe, needs a rear cat $150
BBB V8 lower intake with BRAND NEW 42lb motorsport injectors (this is VERY RARE)
$500
V6 direct port nitrous kit.
Includes, NX maximizer, FJO Wideband, all software and cables, intake manifold already plumbed, 1 gallon fuel cell, seperate fuel pump/lines, all jets, etc. Everything you need to install except racing fuel. This system really will only go onto a cowl hooded car. You will need ONE nozzle, as it is broken due to a sloppy motor mount.
$800
RSL Mase 18x7.5 wheels, no tires, ok shape, could stand to be painted, same as above.
$400
Brand New, still in the box Tri-Flow cams, havent even been opened. $850
$500
$800
$400
