getting hard to shift
Mike Stitzer
PA
Well, now along with the gritty feeling clutch action, my 95 MTX seems harder to shift. It always goes into gear but it's very notchy getting into the next gear, almost like a snagging feeling. Does this sound like a major problem. Also, how can I check the gear oil. What's the best way to add oil? OR is this in some way related to the clutch feeling gritty sometimes?
Mike
centaurus3200
oakland, ca usa
it might be clutch time! how many miles are on yours. also, how often do you change the tranny fluid. just because it is a sealed cse DOES NOT mean you never have to change it.
see ya,
Robby
fredhurderjr
www.neshospecialists.com
"Getting hard to shift"...
Hmmm. Tried Metamucil?
Seriously, my 95 MTX grinds going into 2nd, but the other gears are ok. I've been told it may be low fluid. I'm pretty sure it's up there, as we recently did a flush. Gotta check to see if Merks actually ever did the drain plug though.
If I remember correctly, the fill level is even with the bottom of the fill plug threads on a level surface. Check SHOTimes.
smokesho
Ont,Canada
try adjusting the clutch. it says how in your manual.... i found it helped when mine got a bit finicky
SilverSHO
cartersville
Okay, I read the article on sychronizers on the "How Stuff Works" site, so I know what the grinding is. Just thought I'd chime in, since I haven't made any useless posts lately and I'm overdue
Nick
Lt. Titanium 90 135k
Coneless, ACCEL 8.8 stainless steel wires,
SHO Shop torque limiters, Cherry Bomb Turbo II mufflers (sound pretty damn good for $15 mufflers :D )
New to the family: '73 VW Beetle...MUCH less expensive to mod than the SHO, but somehow not quite as much fun ;)
AIM: loudog6491
