92sho16
b00sted
Ok, so i went to a local scrap yard and found a gen3 sub frame just laying on the ground i figured i just had to get it. I have searched and read all i could read on this swap but i think a more clear cut thread needs to be put together on the little details. I know the frame mounts to the body just like the others and the trans mount needs to be welded on and the gen3 spindles need to be used so on to questions.
Do the motor mounts need to be fabbed/swapped as well?
As far as steering the only needed change is custom lines?
