Gen3 Subframe Bushing Hardware
FamilySHO
Croton on Hudson, New York
In installing Gen3 bushings on a Gen2 subframe can the Gen2 hardware (bolt, nut washer) be used? Saw something on TCCA which said Gen3 hardware was required.
RonPorter
SHO Club of America
Lake Orion, MI
Yep. It's the same bolt, from what I recall. Same bolts can be used for any type of bushing.
itwonder
VA
I used two of the Gen 2 subframe recall kits (2 bolts in each), which has all the fastener hardware needed, except as 93RevSHO pointed out, you don't use the big washers. The old bolts can be used, but most are corroded and it's best to install new.
