Gen3 Front speaker upgrade part 1 of 2
Qshiplvr
P Springs
Now, listening to the radio, the OEM speakers have given their all, and some were totally non functional. I decided to fix that.
I took to Amazon, and ordered replacement door speakers that fit (5” x 8” door hole, 1” silk dome sail panel tweets):
OOeXkjHXup2RP3Im3tC3nbNDYUzn9ySt69nmTYHGBICSA7eJdA Q fnbM62m7xFu9GBxsh7voci54PKpmpjK551BAUHpXord8uqqq
Metra 72-5512 speaker harnesses (note the gender of the plug (female?) – this is important later :
YSGgHci91ID2OYx2srno6zqY HDAFlrVr7IW0pFC 1Q76giZbn
Went to Rock Auto to order the Doorman Christmas Tree door fasteners (10 to a box):
TcEZpyWLvIj0n NDWS5l0O1duX4nvGoUP2I82GlE0pL4Bw6bDd
You may want to visit your local Harbor Freight and pick up these tools…it makes a WORLD of difference in helping to pry the door panels off without killing the Christmas Tree fasteners.
NWKLuYH4VAuKbvbt1JHbXe2nqCCKckYbj noMGnSxG5iUgGfLf
After unscrewing the 3 screws along the side of the door panel (2 on the B pillar side, 1 in the jamb on the A pillar)
6JaCH8RlG4m 6Nz9 L6sgyq1Rugmai1vKTWfj oXsOYjUuF5GP 533v1zMrBkEuBgB55mABoI35McgoPGt57nRQYx5VCFa3uWlczE
And unscrew the one screw in the door handle cup
7fsAF ohAFNSCHyMP9MtqwXwPlpUviUPNK0E6RcjSECqae04 p
Be careful to take out the small panel behind the door opener lever (pry from top towards you then lift to clear bottom tabs)
NYU0C5JNzBInEACrSyXH9Hu qSsrxJQa67kxe54JKpuc395CsU
Use one of the Harbor Freight door puller tools to pry the door panel away at the points where the fasteners are (there are 11 per door panel)
SfYMy48jUcPaaGD5Yl4y9prehZZ gzM2j9N0lX19b 7GuEsGUe ROKB2LABGgz0MoU0Ej Mn9tWcC9r6Uz Hem76GUIyJJVouM4N0
Driver door fastener locations Passenger door fastener locations
H y 3 Qvc5KfVFj7h 6L7xqrS5OcAbZsg0JtE0JVBE1Nicjpfc
Passenger door OEM speaker backside
WDgq73URKOlQ0o8oxExcrY45bPHPiSx5YS0VNOT7RE0kd4qOH4
Passenger door OEM plug and harness, disconnected OEM speaker
YfMefJy2tSSdpt8Bvfpguo r5zzreBxOKsZSgpsilt8Ox6XvOc
Pioneer TS-D6802R 6” x 8” speaker and Metra harness to plug into OEM Molex
R97BpwjjaCRnb JpTvtxgjPVHbgGfh9vGZlE80lOqI Kfrfw2A
Pioneer TS-D6802R 6” x 8” speaker and Metra harness closeup Molex
PNTVuPJoBOIeeNsdis1q5q2ijWe1rjHiUcGo4Y9gHviMIDz5iQ
Pioneer TS-D6802R 6” x 8” speaker and Metra harness taped up for install
R8MNs rSuPzjdgmDhnOaQcQZE 2o4k7DkenOJZyf0jnb ybd48
Pioneer TS-D6802R 6” x 8” speaker and Metra harness installation
GwWBSMl7oM0digckQb4abH2vnlGh x3f2HHflOGnbRuc WvFUo
Pioneer TS-D6802R 6” x 8” driver door installed w/ reinforced moisture barrier closeup
ANO93WBMcNN0DFg wIM M0qrMrj5mQmJU8P m t1M7E4tdzpMg
Pioneer TS-D6802R 6” x 8” driver door installed w/ reinforced moisture barrier full door
Qshiplvr
P Springs
Gen3 front speaker upgrade Part 2 of 2
Tweeter Sail Panel enclosure modification and driver upgrade
OqfXDmXZXAzkGIQZIknqMhxYdXygUbdzMHIOHfKqGyAV4c3GWM
Tweeter Sail Panel cover removed
Tb7c4WNFlZRPbTQ0Q2vujh1CSgOv5Ip7DKXXDwt7ME2J3g2l4Y
OEM Tweeter mounted under sail panel cover. Note the high-pass X-over grey packet beneath
Remove Sail Panel enclosure, this is what you’ll get
QHhtmvAgxF1M82w79DVRxviaRvOJ1YUsnfHMgulyxzRlZm3Il4
OEM front sail panel tweeter front w/ high-pass X-Over
AxFGCzkVhTGrdwagBs4GdaayaImZERxiJ0e4bRagL0lVV6 XvE
OEM front sail panel tweeter rear w/ high-pass X-Over
ZD7CiiyO48ff8aT5LJdR6VtvrDNC1jWuOPP4n5HztN597FdXZg
OEM toasted tweeter - Note ****** mount screwholes & high-pass X-Over
Because the tweeters I bought were SURFACE mount (not ****** mount, as per the picture above), there is a problem in that there is no surface to mount them TO in the sail panel enclosure. So, using an old carpenter’s trick (thanks to my husband, the carpenter), I took an old paint stick, cut down to size and hot glued the brace in the hole into which the tweeter will be “surface” mounted.
Qn1j6vOoExFPUmxTT4LPqeCMAPKbpiEaAYZAowHA8Zwg3fzZ c
Sail panel enclosure w/ paint stick brace trial fitted (no hot glue yet). Above showing the mounting plate positioned on the passenger side brace to show how mounting screws will bite into brace.
QBJkVxFkr9MyFBxjQFO5HZWRx6a3L06c8ZMZIhVWiGwI3C eVE
Paint stick cut down brace hot glued into enclosure
DH PnK5bOn2VHDV8kWvWIA8r7geZBpD36XkpN YkpCTH57c9QU
Mounting screws, base plate (on right) tweeter driver that will bayonet mount onto base plate in middle
Ij7AssA1f1 Ah3hA1y9hVRaHh6dQg48NEba9Ro6NKhQzNKLgVY
Base plate screwed onto paintstick backing, tweeter driver before bayonet mounting into place
7lgXPSzAd0yeCvt2mk4gDpwEyVTEYqiYaX8nvaLSVJ3UoLnBIc
Close up of bayonet mount tweeter (left) and mounted base plate screwed into sail panel
M5UDX9y DdpjJ3paXXQR3ccInPz8OFhA8eqvTR16Fm3wltIlbw
Backside of mounted tweeter, taped to reinforce hotglue mounting of brace
Y79XWQjj1we1WGVWGcSfPchuq5GKqGb0CiyDbfsf8PS9egpVtY
“Exploded” view of surface mount tweeter showing back plate, bayonet base, driver and dome cap. In background, finished mounted tweeter.
D07EcARMxY 9LTmPpSHXw9uqJavEbHA MQ9HnE1XjUS3VyAC1U
Sail panel tweeter “surface” mounted on brace, angled towards passenger
RAKqwrA8rKB0AFZgwhKWe7k 3UGRshEfSEbJ fp2CS5j3vMEoY
Don’t forget to harvest the OEM high-pass X-over and solder the X-over in line w/ new Tweeters
WtiwYa7I5ktbDtmKCRpB8uG9rEsnBVhpY02EIjAZzg0OKTbFL4
Back of OEM high-pass X-over. Be sure to keep polarity of IN and OUT wires correct
XbCTH5YaTA49LhzvkFlW KXRbzVVXLSZpUcipX23mwaefaso9Q
New tweeter mounted in sail panel w/ high-pass X-over re-wired to Molex plug
CNEd9DaGOJsAsyP5UQltbGQJtKi3v3gMWMC JDM6zJQ6BxODZ4
Hi-pass X-over wired to sail panel zip tied and plugged into door harness
T gruOE2NThhq9PM4klBR0XW9cHxiBtymXpz4bpwBedVrpTK6Y
Driver side tweeter sail panel mounted and zip tied plugged into door harness
7CH0OiSdu6mZMqPgIDKNXKlEzzkkw3J8qkBadQpP37hKEoc6cc
Passenger door drivers upgraded and installed, plugged in w/reinforced moisture barrier full door
Qshiplvr
P Springs
I forgot to write...now reinstall the door panels reversing the procedure when you removed them. I didn't take any pics of the start/finish figuring you guys know what your doors look like.
Qshiplvr
P Springs
I don't understand what is so wrong about the word "f l a n g e" that was ****** out in my write up above.
Yeah the word police software is stupid. I almost miss installing stereo equip.
Glad you took pics of the step by step.
Qshiplvr
P Springs
The moisture barrier is the stock one that came w/ the car. I just taped up the edges w/ heavy duty black duct tape (Gorilla, from HD, I think). The sound quality improvement was HUGE! Now that there are working tweeters in the sail panels, and that extra 1" in the base drivers up front and stiffer cones make it almost sound deep enough to not need a subwoofer (almost). I thought it was kinda odd to order a 6" x 8" speaker but Amazon said it fit the 5" x 8" hole, so I trusted in Amazon, and it was really worth it!
Qshiplvr
P Springs
I want to add, that the improvement in bass response is probably due to the fact that I sealed the airspace in the door cavity by taping up the moisture barrier effectively turns the door into an infinite baffle speaker enclosure. If I didn't do this, I'm sure my sound quality improvement wouldn't be so dramatic.
Qshiplvr
P Springs
Come to think about it...if you look at the picture of the full door, and realize the moisture barrier really functions not as a rigid surface but one more akin to a kettle drum skin, the entire covering is probably acting like a passive radiator to increase the bass response. I'm not an audio engineer, so can't really speak to specifics. I'll leave that to all the engineer types out there on the SHO Forum.
Thatredsho
