Gen3 HID headlight housing modification part 1
Qshiplvr
P Springs
View media item 86View media item 87View media item 88View media item 89View media item 90View media item 91View media item 92View media item 93View media item 94View media item 95View media item 96View media item 97View media item 98View media item 99View media item 100View media item 101View media item 102View media item 103View media item 104View media item 105
I went full boat Theretrofitsource kit, buying their H1 mini. Need to do surgery on the new TYR replacement housings. Here are pics:
1) Disassemble
2) Cut ****** until flush with back curve with Dremel tool (or hacksaw if you are maso) have a vacuum handy (lots of dust)
3) Barrel sand 3 tabs inside hole until the hole is smooth
4) Test fit projector
5) Ensure lock nut on back is FLUSH, otherwise go back to step 2 and sand down more with hand sander or sandpaper and block of wood
6) Scuff reflective side with sandpaper in prep for paint
7) Drill holes for high-beam wire plug, first with 3/8 pilot, then hog out with 5/8. I used blue painters tape to start the bit as the surface is curved. Be sure to position LOW (close to bottom) enough to leave enough space for projector (hence the test fit from part 1). Remember: Measure twice, cut (or drill) once!
8) Paint interior black, masking off rubber using duct tape (it was the only thing I could get to stick)
9) Fit the plug and grommets into drilled holes
10) Seal wires and grommets with Silicone glue
11) Attach grounding ring. This is why you need to make sure it was flush above (see part 1). If it is not flush, you will not be able to attach this ring, which holds the bulb.
12) Install the bulb (USE GLOVES!!!)
Finally figured out why my lights were reversed, thanks to Thesubtleknife (TCCA member) and others postings. Motocontrol unit ships in 9007 configuration. I had to swap the pins in the blue connector so the low beam wire and high beam wires were reversed, since Taurus switches ground, not hot. LOVE driving at night now!
BI-XENON MORIMOTO MINI STAGE III (H1) 2 x Morimoto Mini H1 LHD (7.0) $120.00 2 x 35W: Morimoto XB35 Computer $70.00 2 x Morimoto XB Igniter (AMP) $30.00 2 x H1: XB 5500K $25.00 2 x Ocular $25.00 1 x MotoControl Bi-Xenon: 9007/9004 $25.00 1 x Black: RetroRubber $12.00
Total shipped: $307
Bought new TYR replacement housings from RockAuto, about $50 each.
shoftw
Nice, i want hid's with projectors but don't know if i want to attempt to do that myself.
gamefanatic
Barstow, CA
I've been looking at doing this to mine for a while, Glad to see people are still looking to do this. I bet things are much better at night! I always want to drive my Cadillac at night since it's lights are so much farther reaching than the Taurus'. Congrats!
Next up halo's!
