Gen 4 Tech Data (quick ref)
N8rfastback
NE
I wanna make this thread for a compilation of tech data for quick reference for us SHO owners (GEN 4).
Ill start a list and we can add to it as we go if we find more stuff:
Oil: 6 quarts (2010: 5W20) (2011: 5W30)
Motorcraft semi synthetic from factory.
Oil drain plug: 20 lb-ft
Oil Filter part numbers:
Fram: PH10575 , TG3600 , HM3600 , XG3600
K&N: HP-2011
Hastings: LF134
Motorcraft: FL500S
AC Delco: PFL400ACL
STP: S10590
Cabin Air Filter part numbers:
Motorcraft FP68
Heated/Cooled Seat Filter Part number:
Motorcraft FS104
Engine Air Filter Part numbers:
STP: SA10242
Fram: CA10242
K&N: 33-2395
Replacement Filters for Airaid Cold Air Intake:
Oiled Filter: 720-479
SynthaMax Filter: 721-479
Wheel Lug Nut Bolt size and torque:
19mm , or 3/4"
Wheel lug nut torque
100 ft-lb / 135 N•m
Stock spark plug part numbers:
Motorcraft: CYFS-12F
E3: E3.66
Champion: E7437
Champion CHA9901 (Iridium)
CHA7437 (Double Platinum)
Autolite APP5364 (Double Platinum)
XP5364 (Iridium)
Denso 5339, 5340, ITV20, ITV22
Stock tire sizes:
255/45-19
245/45-20 35 psi cold
Sony audio system troubleshooting
http://www.shoforum.com/showthread.php?t=117457
Light bulb replacements:
Low series headlamps
(high/low beam) HB3
*High series headlamps
(high/low beam) (HID) not given
Front park/turn lamp 3457NAK (amber)
Sidemarker lamp (front) 168 (amber)
Tail/sidemarker lamp (rear) 916
Tail/brake lamp 3057K
Backup lamp 16W
License plate lamp 168
High-mount brake lamp LED
Supplemental park lamp LED
Map lamp W5WL
Dome/reading lamps W5WL
Turn lamp T20 (amber)
Thats what I have gathered so far, We'll add to it as we see fit for quick reference stuff. Great things would be spark plug numbers, stock tire sizes and cold PSI, etc.
Pretty much a quick reference for the periodic maintenance stuff for the DIY guys on the forum. I usually make a spread sheet for myself and save it on my phone, and figured it would be helpful here as well.
-Nate
SHOrod
Torrie Tuned
Cedar Rapids, IA
Per the owner's manual:
Retighten the lug nuts to the specified torque at 100 miles (160 km) after any wheel disturbance (tire rotation, changing a flat tire, wheel removal, etc.).
1/2-20 UNF
100 ft-lb / 135 N•m
-Rod
N8rfastback
NE
Lets see if we can make this a sticky and Ill just edit the first post whenever we get new stuff.
-Nate
mjhpadi
Pennsylvania
N8rfastback
NE
Thanks for the additions guys. Ill have to look up stock tire sizes and the cold psi as well.
mjhpadi
Pennsylvania
Just discovered that the socket size needed for the lug nuts is a 19mm seems to fit a bit better then 3/4" which also fits.
N8rfastback
NE
Well Ive added a bunch just in the last few hours... I gotta get the PSI off my doors for the 19" and 20"s and add it into here still
mjhpadi
Pennsylvania
Mark -- the 3/4" is fractionally larger (5/100ths mm.) than the 19mm
Told you I wasn't very familiar with the metric system! :rofl: Or maybe it's the inexpensive lug nut socket set I bought at Harbor Freight! Will check them again. :banghd:
Showgun
Canuck SHO
Cambridge, Ontario
No worries Mark, They'll both fit because they're so close in size but the 19mm will fit just that little bit snugger.
SHOrod
Torrie Tuned
Cedar Rapids, IA
Stock tire sizes:
255/45-19
Given the performance orientation of this car I think it's prudent to add that the factory tires are ZR-rated tires (at least that's the case with the PP) but based on what I understand the factory speed limiter to be set at, V-rated (and realistically probably H-rated) would be safe if the speed limiter is still in tact.
-Rod
Showgun
Canuck SHO
Cambridge, Ontario
I forget where I read it exactly, could have been Motor Trend's writeup on the SHO, but I believe the factory top speed of the SHO is about 150 mph. If so, a rating above H would be appropriate.
Can someone verify please?
Showgun
Canuck SHO
Cambridge, Ontario
Ahh, okay. I thought I read on this forum that the top speed is limited in the factory tune to 133 mph. There seems to be a lot of questions about this with no real confirmation.
-Rod
Yeah, info seems to vary a lot -- would be nice to know to what extent Ford limits these car's top speed.
Our SHO's up here come with V rated tires which are good for up to 149 mph.
That doesn't mean the car will do it, just that the tires could do it safely.
It does seem that some of our members have tested the SHO's limits if one can believe the speedometers.
The trouble with talking about this is that sooner or later someone will go out and test the car again which really isn't what we want here.
All we need to know really is that the tires will cover our butts if and when the car goes at an excessive speed.
Speaking of which: those of you who have tunes which eliminate the factory top speed may be able to exceed the factory speed ratings on the original tires.
Don't forget that if you're going for top speed, you best have tires that are rated correctly.
Happy motoring.:)
darreli
Run'n from BPD
Michigan
K&N: HP-2011
Hastings: LF134
Motorcraft: FL500S
AC Delco: PFL400ACL
STP: S10590
Motorcraft FP68
Motorcraft FS104
STP: SA10242
Fram: CA10242
K&N: 33-2395
19mm , or 3/4"
100 ft-lb / 135 N•m
Denso: 5339 , ITV20
E3: E3.66
Champion: E7437
Stock tire sizes:
255/45-19
-Nate
You can add:
Spark plugs
XP5364 (Iridium)
Denso 5340 ITV22
