NoSlo
SHO Owner
The G2 Taurus SHO uses a ABE Teves Mark IV ABS system. The computer and the modulator are all standard components, the pump it uses is optional (to recover pressure after ABS operations). Even when installed in different cars from different manufacturers, the ABS computers all use similar pinouts and connectors. The ABS computer likely gets some model-specific customization - number of wheel speed sensors (which can be less than four), number of sensor teeth & wheel diameter, options, etc.
Here's a relevant and useful video for diagnosing this ABS system, as used on a Buick. The codes, pins, and diagnostic procedures are the same. Even look inside the ABS valve body.
Now what's interesting, and gets one thinking - this ABS system also had a traction control option the car manufacturer could have selected. It could apply brakes to the slipping driven wheel when operating under 25MPH, transferring power to the non-slipping wheel. Mainly snow/ice traction, but also a poor-man's launch spin control.
The 1994 Thunderbird SC had the traction control option installed, but for rear-wheel-drive. The Buicks in the video have traction control for front wheel drive, the way we'd want them to work. 94 Buicks can even signal the ECU to reduce power. On 1994 BMW3, you'll find the ABS + Traction control + Stability control using this system + dual pumps.
Parts required for this:
ABS Modulator body with two extra valves, plus pump return lines,
ABS modulator computer with traction control enabled, ideally FWD to avoid re-wiring or re-routing,
(Brake pedal position sensor), especially for SC, or pressure switch for TC
Lots of wiring (and some re-hosing?), new bracket for ABS modulator.
Maybe ABS master brake cylinder with return lines (?)
This could be a long project for little performance return, but my interest in the possibility is already piqued...
BTW, it looks like running the ABS pump manually in our cars might work as a built-in "power bleeder", which can be accomplished not just with the dealership ABS bleeder diagnostic module, but also by just plugging into harness with your own homemade "module" or plugging into the the ABS module/pump with your own junkyard pigtail. I'm going to a wrecking yard to get the last option to make an ABS flusher.
(Later Teves Mark xx systems even allow you to use the traction control button and brake pedal to do the valve body flush procedure without any expensive diagnostic tool
BMW ABS + TC + Automatic stability control
