gregrob
Hi guys, I joined a few days ago but just now validated my account so I could post.
Let me say first that I have searched and done a lot of reading so I wouldn't get flamed by the masters
My problem is, my car is hard to get into 1, 2, 3rd gears. If I go slow and let the synchros slow down, it will go right in, but it's at least a 2 second delay. (not good when beating up on a ricer, gives them the false impression they're almost as fast as the SHO
Sometimes it doesn't want to go in 1st from a dead stop either.
The trans shifts butter smooth easy when the engine is off.
From what I gather reading on here. Texan tony has a shim mod I could try.
I could try a new clutch cable.
Cut the carpet from under the clutch pedal,
or I have TOB / PP problems.
What do you guys suggest I try first?
Another thing: I have a sensor on top of the trans near the clutch arm that is broken off and unplugged. What is this, and where do I buy another one?
I was thinking if this is a speed sensor of some sort, it could contribute to my shifting problems?????
My Car is a 1992 MTX, dark blue with white slicers.
162.*** miles.
I've had the car for over a year but haven't put many miles at all on it.
My plans are to do a full 60K, valves, t belt, water pump, CPS, etc.
Rod bearings.
get this shifting thing figured out, and maybe a hi po clutch.
Then, a 75hp wet shot
Thanks for any help you can offer. I wanna get this baby shiftin smooth, cant stand grindin em and I know it's baaaaad for the MTX.
)Sometimes it doesn't want to go in 1st from a dead stop either.
162.*** miles.
Rod bearings.
