Fuel System
LowSHO
Westchester County, NY
I ran the codes on my '91, got an 87 - which says to check inertia switch, FP relay, and fusible link.
Inertia switch is ok, fp relay is ok, but I can't find the fusible link.
Any help?
SHO--ripper
928 Euro
winsted,CT
Did you check the fuel pressure on the fuel rail. Sounds like you have a bad fuel pump. My car threw a bad FP relay, i replaced the pump and it ran like new. Is your car down on power? Does it idle low then stall out?
LowSHO
Well, it seems a little down on power, but I don't trust the "butt-dyno."
I do think it's a fuel pump problem that requires a replacement, but I wanted to go through all the other tests first before I drop the tank.
As an update, the fuel pump only cycles for a split second now when I turn the key on.
I tried the FP jumper on the EEC module earlier and the FP would cycle for 2-3 seconds before shutting off. I believe it is supposed to continue to cycle in that mode.
As to pressure at the rail, I haven't gotten a pressure gauge on it yet, but when I depress the relief button inside the schrader valve, all I got was a short spurt, then nothing.
If the engine was running, I got a steady stream.
The only code it threw was "87", which indicated an electronic problem in the fuel delivery system.
So I am just trying to check everything before I get down there with the rust and the beater bar.
Any help would be appreciated.
Thanks.
SHO--ripper
928 Euro
winsted,CT
I know what you are talking about. When i did my fuel pump there was so much rust cuss . I snapped one of the bolts. :mad: If you end up replacing the pump take your time and use lots of liquid wrench/PB blaster. Good luck.
