LowSHO
I'm a relatively inexperienced mechanic. My 91MTX was exhibiting symptoms of fuel starvation, intermittent stalling and hard starting.
I ran my codes: 87 and 96 koeo, 87 stored (couldn't run koer)which pointed to the fuel pump. So I went to this forum for instructions to test the fuel system and the fuel pump would not cycle long enough to take a reading (it would stay on less than half a second).
So I replaced the fuel pump, and the filter while I was under there.
The symptoms persisted, although the new Walbro 190lph would run "normally" at startup. Fuel pressure test results as follows:
With the FP test point grounded, I got 32 lbs static pressure - however, the fuel pump would not run continuously, only for a couple of seconds, then shut off.
I reset and tried again. In relieving the meter, I got very little gas and a lot of air, I thought perhaps there is air in the fuel lines from the pump change (although the pump should take care of that, I believe)
Priming the system several times until I got only fuel from the pressure discharge, and then priming the pump 3 times, I got 38 lbs static.
I then tried a single prime on static (still with the FP test point jumped) and only got 32 lbs.
In each case I waited 3-5 minutes for the leakdown, and in each case there was no change at all in pressure.
I then did the engine on test, got a solid 40 lbs, with virtually no change across a range of engine speeds (FPR plugged, FP test point not grounded).
What should the FP be doing when the test point is jumped - running continuously or running up to designed pressure? Mine gets up to the right pressure, but shuts off.
That air in the system bothers me, anyone have any idea why it was there?
My koer codes were 25 and 73. There was no pinging, so I ignored the 25, and I thought I goosed the engine well enough to void the 73.
I had replaced the ICRM (containing the fuel pump relay) earlier. I can hear the click and the fuel pump when I turn the key on.
Advice is greatly appreciated.
