?fuel starvation???
J.L.Gordon
Carlsbad,CA
Well this is what I did ,installed new 190lph fuel pump,new fuel filter,new lpm chip,new lateral rear control arms,new bushing all of them new struts springs,29mm rear sway.
Now driving down the road within two miles the car starts to stumble and then die's,it will start right up but act's like its running out of fuel after about the 5th try it will start and run fine the rest of the trip.When I shut it off and then we go thru this session again.Any idea's rant
Did you install the fuel pump with an awareness of the polarity of the wires? How about the fuel filter and the flow direction arrows? I would also pull the LPM chip and see if it makes a difference.
crystizel
