Fuel Pump
bigred56k
N.A.B.
Grand Rapids, MI
The Fuel Pump wont turn on, It was just replace before i bought the car. I checked the switch in the trunk and it is reset so im lost....Any ideas???
Porkchop
The Black Sheep
Virginia
Relay is under the hood in the fuse block, CCRM at least on the g3's is located on the side of the battery strapped to the tray. I think on the g2's its under the shroud on the rad. support
bigred56k
N.A.B.
Grand Rapids, MI
well this ccrm trip a code if it is bad? Also yesterday I looked thru the cars manual and did not see a fuse or relay just for the fuel pump its self.
projectSHO89
SHOless In St L
EMB2580 said:
Uh... where is the fuel pump relay and ccrm on a Gen One ?
In that metal box under the plastic panel screwed to the top of the radiator support.
It is not considered a replaceable relay.
Steve
bigred56k
N.A.B.
Grand Rapids, MI
Hey guys I figured it out, i had 4 fuses blown and a wire grounding out under the dash running up to the ignition. Thanks for the help tho.
Tony
