Fuel Pump Question
sho_can
Salt Lake City, UT
I'm planing on putting a new pump in but I've heard that I can put a mustang pump in, does it fit so I don't have to modify any thing? and how much would it help a stock (except K&N panel) SHO??? I've don't the hole trap door thing, so getting to it shouldn't be a big problem if i need to later on.
Thanks Every one
For the higher capacity pumps (greater or equal to the 190lph Mustang pump), you will have to trim the metal tube at the pump's output to allow the pressure damper to fit. You should install the pressure damper. It was put there for a reason.
