Fuel Pump not running, Fans always running.
TheVancen
Ontario
My 91 SHO has been sitting for about 3 weeks while I did some metal work in the right front fender well and I tried to start it to day and the fuel pump isn't kicking on, and the fans are stuck on.
The negative cable from the battery was disconnected while I was welding. The inertia switch has not tripped.
I do not see any pinched or burnt wires around the PCM on the engine side. I did have to remove a few ground wires so if anyone happens to have a picture of the I side of the right front fender that would be appreciated.
Is there a way I can jerry rig the pump to move the car?
fans running all the time as soon as you turn the key to "on" is a symptom of: 1) a bad connection to the pcm, or 2) a bad ground.
Did you disconnect the pcm while you were welding? If not, you likely killed the pcm.
I would look for bad grounds anywhere that you disconnected stuff while working on the car.
kevinspann
Don't take my advice.
Richmond VA
or 3) dead PCM.
There is a ground on the firewall near where the hood strut connects. It is a PCM ground, and the ground strap from the intake connects there as well.
TheVancen
Ontario
or 3) dead PCM.
I'll give it a check tomorrow. That ground isn't one i moved this time, but ill double check it anyways. This car still hasn't gotten sick of kicking my ass.
