My 91 SHO has been sitting for about 3 weeks while I did some metal work in the right front fender well and I tried to start it to day and the fuel pump isn't kicking on, and the fans are stuck on.
The negative cable from the battery was disconnected while I was welding. The inertia switch has not tripped.
I do not see any pinched or burnt wires around the PCM on the engine side. I did have to remove a few ground wires so if anyone happens to have a picture of the I side of the right front fender that would be appreciated.
Is there a way I can jerry rig the pump to move the car?
