shojuan
I guess my aging fuel pump didn't take too kindly to having abnormally high amounts of gas flowing through for the duration of the Pinnacles outing. When I got home I noticed a slight
drop in power coming off the light into San Juan so I pulled the codes to see what gift the SHO had for me. 87 and 96:
87 Fuel pump circuit fault (check inertia switch) intermittent in fuel pump primary circuit
96 Fuel pump monitor circuit shows no power
AIR Bypass (AIRB) not working (Service 87 code first if present) Fuel pump relay or battery
power feed was open
When I turn the key on the fuel pump cycles for only about 50ms instead of the normal 1-2 seconds. The car does start and idle however.
If any of you guys think this could be anything but a bad fuel pump let me know soon because I'm about to spend $80 for a new fuel pump in the next few day. Should I even bother checking the associated wiring before I replace the pump? I just put in a new ICRM module on Saturday and that cured all the major issues I was having with my car. It was solid as a rock until those codes. I really don't want to have to go backprobing those circuits. (Unemployment makes me lazy, and shiftless. But mostly lazy )
power feed was open
