poissonverte
My 2nd pump is now dead.. I dropped the tank last time i changed it but want to do this door through the backseat. My only concern is how dangerous is cutting metal so close to fuel lines? Ive done alot of maintenance myself, but when it involves things that go boom i get hesitant.
PS. done the fuel filter...
From seeing the pictures on write-ups, I knew this side was the closest of all and I used a hack saw. For the rest, I used an air powered cut-off tool with a 3" wheel. If you do that, just make sure it's not a fat wheel. You can also go over the passenger side and weaken it, then use a flat head or something and tap it with a hammer and slide it through going sideways.
