**************fuel problems******************
90 white sho
northwest suburbs, IL 60195
I cant hear the fuel pump when i turn on the car to accecories position, the car will crank but not fire, is there any chance maybe a relay is bad on the fuel pump or something to that nature, throw some ideas out for me.
clintonk
Apex, NC, USA
First check the fuel pump **** switch in the trunk. Then check your fuses. If those are OK, you can ground the fuel pump pin in the self test connector and listen for the fuel pump relay in the integrated relay module over the radiator; grounding the pin runs the pump constantly so you can then start probing wires to see if the relay or the pump is the problem.
Clinton Knight
'90 White 182K
'95 Green 50K
