fuel injector angle
sho4life
midwest
when putting in new fuel injectors do they need to point a certain direction in the rail for it to operate properly? i still cant find out why my 92 mtx has no power
ycode90
Out in front!
You should "clock " them so the holes in the tip are inline with the valves. Does that make sense ?
sho4life
midwest
Yeah the two little holes should line up but if they dont will it run like crap?
yamahaSHO
E85 whore
Arkansas
No. Most aftermarket injectors don't even remotely line up or even have a spray pattern like the stockers.
firebat45
Edmonton
Check for a leak, the injector o-rings are difficult to get a seal on. A leaky o-ring can cause rough running and low power.
I clock them so all the plugs are easy to connect and disconnect. Never paid any attention to the tip. Never had a problem with them either.
sho4life
midwest
i put new seals in them and pushed them all the way in . i dont know how they could even leak. what exactly is clocking?
Devin
3.Slow
Pacific Northwest
Imagine: a clock.
ie: rotate them. Personally, I just put them in so that the harnesses would plug in. There was not much room for rotation on mine.
Phoenix
SHOHOLIC
QC , Canada
There is a website where it shows you how to install bigger injectors , and it also explains exactly how to lign them up , but I forgot the linky. Maybe someone remembers.
