BaySHO Performance
PFE sensor from the deleted EGR system.And what is this thing? It's just laying on top of transmission.
I'd have to pull it to see what it is but according to original owner it was sent out and remanned ...not sure which one 94 hasCheck your Power train Control Module (PCM).
Your best option is a X2J which is the manual transmission model computer. You may have the W2Z which is the California model.
At first the code reader could not get any codes. The paper clip method seemed to jog its memory. Then it threw an O2 sensor CEL. Something is up, no matter which one you have.
If it still has the W2J, who know what it does to compensate for a missing signal from the exhaust by pass, maybe it pulls the timing, or dumps in more fuel, or whatever. Or it is a X2J that has suffered somehow.
You seem to have done everything that is possible without getting into the electronics, so this would be a start on that path. It is time to swap your 94 PCM into your 92.
Haven't touched o2s, they have@10k on them.
Adjust tps? 2 screws holding it in with no adjustment possible that I can see.
The whole stalling when I pull and then reattach any vacuum hose has me boggled
I'll try that with the tps. I have changed over tps, iac,maf, from a good running parts car. New fuel filter. Motor has 10k since rebuild so plugs, wires etc are all relatively new, just put another set of new plugs in too.You use a multimeter, connect negative probe to ground, and with ignition on but not running, poke into the back of the TPS connector and find the pin that measures around one volt. Loosen the two screws and twist until the reading is 0.95V and tighten back up. On some this may take enlarging the screw holes, on others, you'll already have the correct reading. If it is too high, the ECU may think you have your foot on the pedal.
If you don't want to buy another O2 sensor for the obvious fault, but instead have lots of time, you can swap the oxygen sensors front-to-back, and see that the 172 code changes to a 176. Then at least the problem sensor will finally be on the front where it is easy to change.
Engines like to maintain their vacuum. If you pull a vacuum line, you are letting a lot of unmetered air in, making the engine go lean. It probably then tries to figure out what the **** is going on to try to keep the engine running and maintain idle, such as closing the IAC, and then you go and stick the hose back on again.
Just for giggles, clean the IAC. Soak both of the openings in carb cleaner, and let it stew, and then dump out the carbon and oil. Also spray the electrical contacts clean. If this control is reluctant, the idle speed can't be maintained, which is a little different than your main symptom, which can definitely come from O2.
We assume that you've checked for idiot problems, good spark plugs and wires and no oil in the plug wells. Changed your fuel filter. You could have something as completely unrelated to your haphazard troubleshooting as a glitchy coil or crank sensor, or even ECU ground wire. Check fuses for engine controls, like the heater power for O2 sensors. Even something as bizarre as a blown alternator regulator can make for glitchy overvoltage when you rev up the engine.
And when test driving, it totally sounds like there's a noisy collapsed lifter ticking noise on acceleration and not there on deceleration or when putting any load on the engine just to move it.
Needing rod bearings with only 10k on engine?! Oil pressure is great, 60psi cold idle, 20 hot idleThat may be rod bearings. Try to pinpoint where the noise is coming from.
Must be something else, then.Needing rod bearings with only 10k on engine?! Oil pressure is great, 60psi cold idle, 20 hot idle
I try to upload a vid of the noise but always says too big a file.Must be something else, then.
