I'd be surprised and bummed if it was rod bearings especially with only 10k on rebuild.That totally sounds like a bottom end bearing, heard from inside the passenger compartment. You first video shows the sound lessening when the engine is unloaded between shifts. Sorry.
It can sound like it is coming from elsewhere, a recent thread saw the owner opening the top and front, only to finally find the spun rod bearing. The tick of a rod bearing is transmitted into the rod and piston, and into the crank. You need to roll it up on ramps and get near the oil pan to not be deceived.
Cam chain tensioner sounds like you'd expect a belt slapping around to sound. A valve that shot out a shim, making a cam tap, or is wedged, hitting on the piston carbon that could also sound like that are long shots. These wouldn't care how much gas you gave the engine.
(The flappy slappy of an ATX timing tensioner is a sound I also hope not to hear again...)
A wishful far in left field is you got terrible octane gas or mixed with diesel, and a high compression cylinder from carbon etc, along with a bad knock sensor...and maybe slipped a timing belt tooth or poor injector.
I used a stethoscope on it tonight and oil pan and bottom of motor sounded quiet for any of that noise, mostly heard it at top towards the front of the rear valve cover and block.
I've had a couple people mentioned TOB.
Bad injector?! Hmmm ... I am having severe running and idling problems with it, hence what this original post started out for... Could injector make that noise and also cause my idling and running problem at the same time?!
