I have some questions for you guys who are experts on using FORscan:
Background: I am thinking of swapping a 2.3 EcoBoost from a late model Ranger into my 09 Ranger. I am in an area where I need to pass emissions tests every 2 years, so I need this to be clean from the regulatory standpoint. I work at a Ford dealer, so have access to all the factory wiring diagrams, etc. through oasis, but I do not work in the shop so I do not have access to any of the Ford service computers.
Questions:
Can I delete or deactivate unused modules? I would be using the 09 airbag system, abs system, etc. so would need to turn off the 21 systems that don't exist in the 09 chassis
Can I update the VIN in the pcm so that connecting to the obd port reads the chassis vin?
Would you recommend pats delete or swapping in the column/wheel from the 21? Why?
What other "gotcha" type issues do you envision?
Is this swap realistic or a pipe dream, given that it has to be emissions friendly?
Thanks for your input.
Questions:
