Forced Power Shopping
ant-live
Durham, NC
I'm consider purchasing a charger. Now with all the differ vortech superchargers available and turbos used on the SHO. Do they all fit with the same or differ set-up.
wicked93gs
Nashville, TN
turbos are pretty much custom kits...the superchargers I dont know about,I think they make kits for the SHO(dont know, my SHO motor is for a different application) I would rather use a turbo....more efficient
ant-live
Durham, NC
Yeah, places like the Shoshop do make kits...but i'm referring to the different units themselves. Like votech v1, v2, S or T trim for example and turbos. Are differ setup used or the same setup for the Gen II.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
All the vortec setups are the same whether is is an s or v trim and I believe SHO SHOP was the only one to offer a vortec kit. The powerdyne setup is different and like posted above, any turbo is a custom job.
ant-live
Durham, NC
This may be a dumb question, but if unit discharge is curved or straight wouldn't that change the setup or hosing?
Sho-Driver
Peter Pan
The Garage.
The S-trim is the most commonly used. There will be some use of T-trims and E-trims VERY soon and feedback will be provided. The reason some of us are going with these two trims is to run more boost, effeciently (cooler).
You will need a straight discharge, CCW rotation. If you were to get a hold of just the mounting bracket, you could fabricate piping with an intercooler.
