Foglight Switch
Jayman
Edmonton, AB, Canada
Does anyone on the forum know where, and or if the foglight switch bulbs can be obtained. I've tried the dealer and various other sources without any luck. Dealer says buy the whole switch.
Help
Gez89SHO
LEGO SHO
NE Philadelphia, PA
Unfortunately the bulbs are a dealer only item. You don't have to replace the whole switch though, these bulbs are used in other places in the dash (my 89 uses them in the clock also).
Have them search for a clock bulb, they might find it easier. If they still can't find it, try another dealer.
Gezim
1989 Currant Red
coneless, painted SHO lettering
Subframe Connectors, 16x7 Team Loco 143's
gzim.freeservers.com
LSHOC member
[email protected] IM: gzimi
Bizzy
Originally posted by Jayman:
Thanks, I'll try again!
Jayman, thought you might be interested in this. Might save you some $$!
http://www.shoforum.com/ubb/Forum6/HTML/000806.html
Hope this helps a bit.
SHO's are like kids...they test your patience but you gotta love 'em!
Beth
'91 Plus MTX, Mostly stock
K&N Filter, Coneless
Colgan Custom Bra
Racing Series Driving Lights
Mods in the works
Many items on wish list!
Jayman
Thanks guys, I'm not sure what the last post was referring to though. I am looking for the bulbs inside the switch - my switch works fine it just doesn't light up.
By the way we own a '93' MTX and a '95' ATX.
Thanks again
Jayman
Simply pull the switch out and you can see the two bulb sockets. You twist them counter clockwise and pull them out. They are a tight fit so be patient.
I went back to Ford and they do not sell these parts anymore. Even the actual switch is now obsolete here (#F2DZ 15A214 A). If anyone knows how to get these bulbs for '92' to '95' please let me know.
Thanks
Jayman
Originally posted by shotlc:
How do you take apart the switch...I need to replace the bulb too!!
Pull the switch out and you will see the two bulb sockets. Gently turn counter clockwise and pull them out. They are a tight fit so be patient.
I went back to Ford and in Canada anyway they do not carry these bulbs. Even the switch is now obsolete (#F2DZ 15A214 A) and Ford will not disclose it supplier for the bulbs to me. If anyone knows where they can be found please let me know.
Thanks
Jayman
Let me know what you find because have been going nuts trying to find the manufacturer of these bulbs. Ford says they cannot release this info to the gen public. Anyway I need both bulbs for my switch.
Thanks
S
slosho
Guest
I bought the exact bulb you're talking about from my FORD dealer. Show the parts guy the actual bulb. If he can't find a part number then he's a certified *******. Go to another dealer. BTW, the bulb costs like $6!!
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a few "PCV" lines
Lighting mods
Convinience mods
More to come.
Jayman
Are you kidding me? I've been tried at least three. I guess what I need to do is get some decent airfare and fly to New York and buy that $6 bulb.
Thanks for your input, I will call Ford customer service again. Any chance you can get me a part number for the bulb you bought?
shotlc
Toledo OH
Me too, no luck in Toledo. Even tried radioshack to see if they had anything similar i could gerryrig. The salesman felt bad, he had to buy an expensive switch from Ford so he felt my pain.
spasso
USA
I know the original message poster was asking about a Gen2 SHO but they may be the same bulbs.
I also needed to replace both bulbs inside my fog lamp switch on my '89. I found these bulbs at my local Auto Zone store.
Sylvania Part # 2721.
This is a set of 2 "instrument and indicator" bulbs. The pair cost $1.79.
The top bulb has a little green plastic cover on it to make the fog switch illuminate in color. Just peel it off and put it on your new bulb. The bottom bulb ("on" indicator) does not have a cover, instead has a yellow lens that the light illuminates.
I could not readily find this part on Autozone.com.
Hope this helps. :D
spasso
USA
Apparently, the Gen1 and Gen2 bulbs are different. Sorry Gen2-ers. The sylvania bulb 2721 is the correct one for Gen1 fog light switches. It can be described as a mini version of a 194 bulb.
It is available on www.partsamerica.com for $1.99. I am assuming this is also for a package of 2 bulbs.
