Fastball
Ok, about a year ago I had an electrical problem with the bucking and heaving. Tracked it down to the DIS module. Replaced it with one from Auto Zone; F127.
Solved that problem, but ever since then, my low end snap is gone! When I hit 4 Grand with secondaries, she comes alive like she should. MPG went from 25 to low 20's. Re-set idle 3 times. Ran codes, comes up clean. Replaced plugs w/Motorcrafts, (no oil in wells), wires, (A/C Delco's from Rock Auto), new fuel filter, (Motorcraft), cleaned the MAF and switched out K&N to a Fram air filter, replaced camshaft sensor, and did all new brakes & rotors making sure nothing was hanging up. ?????
Now as of late my mileage is starting to come back up to around 24 mpg, but still my low end sucks! Got toasted bad by a GT 'Stang the other day and I used to run with them and even smoke 'em if it was an AT.
Any other suggestions or clues??
