MD Ever
MeanestDad Ever
I see that a lot of you are using the FL-1A filter insted of the regular one. I understand that it provides an increase in oil capacity but are there any reasons not to use it?
ShadetreeSHOguy said:i know from experience, it will not fit a 3.2:banghd:
1stSHO said:You cant even change your own underwear!!!! And you expect us to believe you change your own oil??? Give me a break!!!!
:laugh_ti: :laugh_ti: :laugh_ti:93rev2sev said:Good general information IMO:
While you are down there, take a look at the oil cooler to block gasket. You can do this with your 30mm hub socket (assuming you have one...I didn't until last summer). Chances are that gasket is toast and leaking oil on your starter. You can use your old oil filter gasket as a replacement.
Edit: I guess I just added that to my list of crap to do this spring too....ARG!
unless Denny did something wierd, it wont fit a 3.2 mtx either sir.SHOtime2511 said:it won't fit a 3.2 in a ATX
it will fit a 3.2 MTX swap
Denny did something weird. I have a 3.2L MTX, and I'm rockin' an FL-1A.ShadetreeSHOguy said:unless Denny did something wierd, it wont fit a 3.2 mtx either sir.![]()
